i miss my DOD Grunge pedal.
Started by pazuzu, April 09, 2010, 12:30:49 AM
pazuzu
man, distortion sounds are sooo arbitrary, and i was comparing the new one to my memory of the one i had 10 years ago, so who knows maybe nothing? i'd be willing to bet it is just the quality of the components though.
pazuzu
i got it today, and it does indeed sound different, unfortunately it sound no where near as good as i remember. i busted it open and had a look and there are no micro components so i'd bet that's the difference, since everything put out now uses them.
pazuzu
here's a gut shot for anyone interested:
Brymus
OK you have got me curious after looking at the schematic you posted and the gut shot...
What are the ICs ?(cant tell from photo) and the 9 Qs ?
Does the pedal you have correspond to the schematic you posted ?
And just a thought you could up-grade some of the components on the pedal you just got,and if its fairly old some of the caps might actually need to be replaced anyway.
pazuzu
#24
all q's are 2n5088, except q1, 2, and 4, which are j201.
the 8 pin ic's read 456OD, and the 14 pin reads MC14007UBCP
        FKR9807
sorry, i have never built with ic's except for a cricket, so i'm not really familiar with them, as far as the schem i found i think it's the same one.
Brymus
Thanks,for that
I count 13 100k resistors in your pic but only 10 of them on the schematic.
Maybe I am making a mistake in counting or checking the color bands,if not then something is different,IDK
zombiwoof
I think a possible reason that the pedal doesn't sound like you remember is that it may have gone through a number of revisions, even slight ones, that changed the sound.  It's possible that only the certain version you had at the time sounded the way you like.  I know with many pedals that have been around for some time, companies change the IC type, and component values/types for many reasons, which may change the sound some.  Look at the different versions of the Boss DS-1, which has had I think five different chips in it, and players seem to like one or the other.
Good luck, I hope you can find one that sounds like your original one.
Al
Dan N
Quote from: Brymus on April 20, 2010, 12:49:50 AM
Thanks,for that
While the schematic does include the switching FETs (why?) and superfluous bypass buffer transistor, it omits the 4007 (?) and associated parts. I don't see any source of the 4.5 and -4.5 voltages either. So, counting parts is a no-go.
No offense meant to whoever traced it.
pazuzu
#28
ok, scratch the original schematic than. it was just the first one i googled. as far as the idea that the one i had sounded better than the one i acquired is probably less likely, i am betting this pedal just sounded better to me when i was 22 and playing on a different rig. after all, the desire to get one of these pedals was inspired by a 12 pack of coors light anyhow.  :icon_biggrin:
here is a better pic of the guts, i have the pedal torn down, and i am not sure what i want to do with it. i only have 20$ into the entire works.
i'm thinking to start getting rid of all the bullsh*t buffering and refitting it to true bypass. maybe replace all the caps with wima poly's or something? i don't know, i have never tried to mod a pedal before, but for the price this could be a nice project.
the fets are the 3 on the right of the set of 4 q's that make a square.
