DIY deluxe memory man with V3205 chips
Started by marconoschese, May 10, 2010, 02:42:34 PM
marconoschese
Hello everybody
I'm Marco from Belgium. This is my first post on this forum but I've been following and reading for some time now. I started making effects about 2 months ago. But before that I've built some tube amps and fixed a couple fenders and peavey's.
Well I'm building a DMM now with coolaudio V3205 chips.
I'll explain what mods I have done to adapt this circuit to these low voltage chips.
U10 - 79L15 .. ouput -15V goes to al opamps except U2 , V3205's and CD4047
The CD4047 and the two V3205's are fed with -5V out of a 79L05. Now I have swapped pins 1 and 5 for polarity (negative supply) and connected the pulldown resistors to the 79L05 completing the polarity switch. So voltages for these two chips should be ok.
The CD4047 runs off -5V too which if you look at the datasheet is a normal operating condition.
When I send a signal in it arrives perfectly at pin 7 of the first V3205. I've tried every position of the bias adjust pot but no signal is coming from pins 3&4 which are the outputs. ( i have a scope)
All the files can be found here : http://www.scribd.com/doc/17686325/Analog-Delay-Layout
What seems to be the problem here?? I have tried to solve this one but for now unsuccessfull.
Thanks in advance. ^^
(on a south american forum i've found a topic with a working version with this pcb, so it's verfied. But that's with mn3005)
