Butler Mosvalve
Started by darthpoodle, May 19, 2010, 12:19:32 AM
darthpoodle
May not be the place for this but asking anyway. I have a Mosvalve poweramp mv-962. It's missing something, that low end thump you get from a tube amp. anyone have any idea on how to add low end. Maybe  a bass switch like the Marshall 20/20. Thanks!
Get a tube amp.
The MV-962 is a transistor amp. Transistors can do about everything tubes can do, but some things tubes do naturally are wickedly hard to do with transistors.
  Not at all convinced the Mosvalve can't amplify LF's.
 Not at all convinced the speaker and cabinet tend to produce well defined bass either [for having no idea what kinds I'm talking about].
  LF's and 'thump' seems to be more of a speaker/cabinet thing for guitars [mostly] since it's not too hard to get modern amplification to work well below the 6string frequencies with modern amps.
 When a system is asked to produce low freqencies fails to impress, the first questions should bring the cabinet and speaker into suspicion.
 Otherwise, I have a Mosfet Pyramid amplifier, it has no troubles at all producing deep/defined bass. Also LM3886 amps that 'thump'.
 Knowing something about the amp and speaker [wattage of amp, effeciency of speaker, LF ratings etc.] would allow better than likely guesses.
The amp can make bass fine.
The amp-speaker interaction is tricky, and critical around speaker bass resonance: "thump".
It's possible to design an under-damped transistor amp, but Darth's observations say this one is highly damped. No easy/good way to change this after it is built.
Transformer effects may also play a part.
Johan
if you look at Marshall's JCM2000 serises, wich is of course a tubeamp, they have a "deep" switch wich is basicly a resonance filter introduced to the feedback loop.
it gives real massive low end.
perhaps something similar could be aplied to you solid state amp?...
http://www.schematicheaven.com/marshallamps/jcm2000_100w_dsl100.pdf  the middle circuit page 1, is introduced to lower left corner page 2
to even know if it's possible, you would need a copy of the schematic for the mosvalve, but perhaps this cold give you an idea..
be warned thou..solidstate amps are not forgiving at all towards tinkering..
J
DON'T PANIC
Caferacernoc
Actually you can easily lessen the damping factor so it has the the interaction with the speaker like a tube amp. Just add some series resistance:
1ohm for a little of the effect. Up to 8ohms, or whatever your speaker is rated at, for a lot.
The series resistance to get "tube damping" is high enough to lose a LOT of power, 1/2 to 1/4.
Caferacernoc
Quote from: PRR on May 19, 2010, 01:31:40 PM
Good thing he has 80 watts times 2!       :)
dschwartz
sounds to me like a damping issue. ..easiest way to fix it is ti put an EQ on the fx loop and boost the 100Hz feqs about 6-8dB....
Of course if you are using 8 or 10 inches speakers, thereĀ“s not much you can do
Tubes are overrated!!
http://www.simplifieramp.com
