Switching between two circuits
Started by John Lyons, June 25, 2010, 10:31:48 AM
John Lyons
I need to toggle between two circuits (master bypass switch and then another switch to toggle between two circuits).
Does anyone have a diagram of something like this. I can't think of how to do it at the moment.
thanks.  John
Basic Audio Pedals
www.basicaudio.net/
jamiefbolton
here is a shot in the dark. and its truly a shot in the dark. could you use a true bypass with relay like over at muzique
http://www.muzique.com/news/true-bypass-with-relay/
and friend of mine was thinking of doing something like this too. but first, could you explain a bit more of what you are trying to accomplish. that may help.
***Disclaimer*** I'm only guessing. I'm not too good at this stuff yet.
jamiefbolton
or are you wanting something like this?.... i have a two channel ROG peppermill. 3PDT one is a master bypass. and the second 3PDT is an "A/B" for each "channel"
is this what you are taking about?
Quackzed
  fx1in--.    .----fx1out
  fx in---.    .----fxout  (from/to master dpdt fx on poles respectively)
fx2in---.    .---fx2out
CynicalMan
If the circuits aren't high gain, you could use a DPDT like this:
Circuit A In º º Circuit A Out
      Input º º Output
Circuit B In º º Circuit B Out
Edit: Looks like quackzed beat me to it.
John Lyons
Thanks Guys, I came up with something in between both of those diagrams.
Just added another pole to ground the inputs when not engaged.
Couldn't get my head around it at first but it is simpler than I thought.
The Bypass is typical and then it runs into the second switch which toggles
between the two circuits. Appreciate the help.
John
Basic Audio Pedals
www.basicaudio.net/
jamiefbolton
Quote from: Quackzed on June 25, 2010, 12:09:43 PM
great! i'm not an idiot. this is what i was thinking.
ahem...i have a similar question...i think.
i want a fuzz and an envelope filter in one box..with one 3dpt.to turn off the fuzz...(master on/off i guess)
.but a small toggle to turn on and off the envelope filter....
is it as simple as just putting the toggle at the input of the filter circuit?....hmmmm....
rob.
