Painting etched aluminium enclousures
Started by ca cat, June 30, 2010, 01:02:15 PM
ca cat
Do you guys use primer on your etched designs? Or do you just spray final coat directly and then you sand it off?
Jamin' with JaM IT FX - www.jamitfx.com
Taylor
I concur, however I've never used primer on any paint job. I will say also that I don't like to lay down a lot of layers of paint when etching because then you lose the relief.
