Question on etching
Started by Jhouse, July 03, 2010, 04:55:31 PM
Jhouse
If I accidently took off too much copper off of the board while etching, can I use solder to just remake the path?
boogietube
I'll usually drill 2 holes and wire it. Then, I glue the wire to the board.
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
KazooMan
It depends on how bad the problem is.  If you have just a few gaps you can bridge them with wire (the cut offs from components works great).
However, I would recommend having a good hard look at the board to be certain that you are not asking for trouble down the road.  If you have a lot of very thin traces, you may lose connectivity later on.
Be certain to examine the toner transfer before you etch and repair any problem spots with a Sharpie or something like nail polish.
