will max1044/icl7660 drive multiple dc outlets?
Started by ninjadave7, August 16, 2010, 04:34:31 PM
ninjadave7
i heard recently that the max1044 chip has a pretty low output amperage.  i wanted to build a charge pump that will power 2 or 3 outlets at ~18V, is there a different chip that will do this?  or a different design than the one on the max1044 tech sheet?
david L
phector2004
Just wanna point out that power out cannot exceed power in
so 9V @ 1A into a chip cannot give you 18V @ 1A out from the doubler. Might not be able to just plug a DC jack into a chip and have it work, BUT
I doubt the current draw from 2 pedals is too much for a MAX1044 though... I think the chip itself draws 325mA. Or maybe that's the output... In any case, it really depends on what pedals you're powering. I believe most pedals draw <50mA
EDIT:  output is 20mA
MAX660 will give 100mA
Scruffie
