T-Shirt transfer over powder coat
Started by MmmPedals, August 20, 2010, 06:38:12 PM
MmmPedals
Do you think it would work? Or would the melting powder coat make a mess of it?
theundeadelvis
I believe power coat cures at about 200 degrees Celsius. The cotton setting on most irons is also around 200 degrees. I also believe T-shirt transfer use the high setting on the iron, so you would likely end up with a goopy mess. I could be wrong, but this is my best guess.
If it ain't broke...   ...it will be soon.
