Jack Orman Mosfet Clean Boost Into Distortion
Started by Chrisq206, August 31, 2010, 01:12:39 PM
Chrisq206
Does any one know if you could turn one of these into a distortion. There's a lot of boost here. It would be cool to be able to add a little grit to it.
www.muzique.com/schem/mosfet.html
CynicalMan
No l on the end:
This is from the DIY Wiki on turning boosters into distortions:
Quote from: www.diystompboxes.com/wiki/index.php?title=Simplemods#Simple.2C_Easy_Mods.2FTips_.26_TechniquesBooster to distortion pedal
Simply add back to back (anti-parallel) diodes from signal to ground after the output cap to turn a booster circuit into a distortion circuit.
You can put the diodes anywhere on the output as long as there's a blocking capacitor before the diodes.
You can put 2 diodes or 4 for more output. You can also use germanium diodes or silicon diodes.
You could also experiment with adding filtering, different kinds and numbers of diodes, adding more gain stages, etc.
