Pot Static
Started by soldernewb, September 02, 2010, 04:26:23 PM
soldernewb
Hi everyone. I'm Cam and I'm a pedal fanatic. Recently I decided I want to build some of my own boxes so I bought a couple of boost kits from another site. Both builds went well, but both produce static when the pot is turned. I am not sure how to remedy this. Is it a grounding issue? I have checked and re-checked all of my solder joints .... ???
I'd appreciate any help or advice you might have for me.
anchovie
If the boost is a clone of the Zvex Super Hard-On, then the knob on the official pedal is labelled "Crackle OK"!  ;)
Skruffyhound
Sounds like DC on the pot as in that ^^^design, if you post the schems someone will tell you if it's inherent in the design or if it's more likely to be a mistake you made. Try to include a drawing of all offboard wiring. Good luck
eddie_bowers
A small (10-50pf) cap across the the boost pot might clear it up.
