Looper is making my head hurt
Started by remmy, September 04, 2010, 06:47:25 AM
remmy
I'm trying to build a looper at the mo and it's not going to plan  :-[
The setup I'm after is for one loop which can be activated by either a 3pdt to have the effect latched on or by a momentary switch.  Here's my first attempt which resulted in a feedback looper  :icon_rolleyes:
I'm starting to think this may not be possible.  Any ideas on how to achieve it as it's making my head hurt!
Cheers, Remmy.
Success is buried in the garden of failure.
remmy
OK I managed to figure this one out and have it working of sorts, here's the wiring...
The pedal is doing what I need but as both switches are connected to each send and return jack the signal is being split and losing volume.
Is there a way round this?  I was thinking about trying some diodes on the wires tomorrow.  I may even put an lpb-1 in there to give it a boost.
Any thoughts?
Taylor
That's not a looper. This.... is a looper.
Ahem, sorry. The answer to your loss of volume is a buffer. Jack has a great page on simple buffers.
http://www.muzique.com/lab/buffers.htm
I would suggest this one:
http://www.muzique.com/images/buff8.gif
remmy
Hehe, thanks Taylor  :icon_biggrin:
I have a buffer pedal and tried it and there was a definate inprovement, however the 3PDT was quite noisy, probably due to the amount of soldering I've subjected it to over the last few days.  So I replaced it and now the looper sounds great without the buffer, I continue to live and learn...
