PCB Etching
Started by Krallum, September 18, 2010, 07:58:29 PM
Krallum
Anyone have any good links to tutorials?
I know i have seen some before but i can't remember where.
Kearns892
This is John Lyon's Tutorial for making PCBs: http://www.basicaudio.net/How-to-make-PCBs.html
I did everything as far as time pretty much verbatim, but keep in mind differences in exactly which materials you use will cause differences. Also depending on what kind of paper you have, the soaking process may not be needed and the paper may peel right off. Also note the current Staples paper is not the kind referenced in the tutorial, and does not work as well for these purposes (http://www.diystompboxes.com/smfforum/index.php?topic=78859.0)
Here are how my boards came out following John's method http://www.diystompboxes.com/smfforum/index.php?topic=36392.msg726769#msg726769
It is not as hard as it might seem. Good luck!
