Check out this Univbie and Phaser assembly for my board
Started by sjaltenb, September 22, 2010, 11:09:11 AM
sjaltenb
So, after changing out a MicroVibe for this NeoVibe for my cornish board, I decided I needed to make a few structural changes and really mount this section nicely.
The Vibe and Phaser are in the same "bank" and share a footswitch. The phase or vibe is selected by a toggle switch.
I really needed the space on the bottom plate to mount all the switches, knobs and LEDs. So i decided to add another level by drilling holes and sending bolts through them upward, and adding another plate on top. On the 'upper level' the Phase 90 hangs below and the NeoVibe sits on top. I have also drilled on the top plate for an internal speed pot (which will be set at "Gilmour" and selected by a switch...the other pot is adjustable and will be external) and also the internal volume control which will stay at Unity. I even added knobs...why not? The charge pump circuit will sit next to it to give 18V in.
All in all i'm really happy with this assembly. It is really strong and gives me access to everything I need on the vibe. Can't wait to get it installed!! I think eventually I would like to add this design to many of the effects in my board. It is much more sturdy than plastic standoffs, etc.
RedHouse
