Big Muff on/off problem
Started by SpufuZ, October 15, 2010, 06:17:18 AM
SpufuZ
Hi!
I just finished a GGG Big Muff that sounds really nice but i have problems with a severe "pop" when i turn it on and off.
Heres the schematic:
http://www.generalguitargadgets.com/pdf/ggg_bmp_ram_sc.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
I have included C15 and R26, but still the "pop" remains.
What could i try more to get rid of my problem?
//david
do a search, im sure your not alone on this!!!!!!...........
http://www.diystompboxes.com/smfforum/index.php?topic=84452.0
SpufuZ
Ofcourse ive searched already!
But i cant seem to find much regarding the BMP.
Instead of focusing on that, lets discuss it here in this thread!
I know there is a lot of people here who could have som input in this matter.
SpufuZ
I solved the problem, i added a pull down resistor after the volume-pot.
The BMP is now completely silent!!
brilliant.... :icon_mrgreen:
what size ?....just for others with a similar problem...
SpufuZ
I know that its recommended to use atleast a 1M resistor as pull down.
But i only found a 150k and it worked fine.
zombiwoof
Did you use the TB switch wiring scheme that grounds the board input in bypass?.  Often just using that wiring will help eliminate pops.
Al
SpufuZ
Quote from: zombiwoof on October 15, 2010, 03:38:39 PM
Al
Yes, i wired it like this:
http://www.generalguitargadgets.com/pdf/ggg_bmp_wiring.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
It didnĀ“t help.
This might be beacause of the Voodoo Lab GCX unit i use to switch it on and off with.
The 3PDT-switch is always "on" and totally ignored by the GCX, so a pulldown resistor after the volume-pot was necessary.
//David
