Passive splitter/blender with feedback problems
Started by jackalkirk, October 28, 2010, 04:57:44 PM
jackalkirk
Need help.  I have designed a very simple passive blender pedal that splits an input signal to an output jack and to an effects loop path that is routed back to the output jack.  I simply connected all the grounds together.  Didn't ground to enclosure itself.  I have the potentiometer set in the input to output signal path (seemed to work better than in the effects path).  Plug in a RAT distortion pedal in the effects path and I get some feedback with potentiometer wide open but, a little bit of resistance (turn of the pot) and the feedback goes away.  So, thats good.  However, if i plug in a phaser, i get lots of strange feedback no matter where the pot is set.  Can I overcome this with a passive design?  I am hesistant to learn how to make active pedals.  I tried a germanium diode, thinking the one-way aspect of these things would do the trick, but doesn't help.  I am also hesitant to put any resistance in the effects path as resistance in both paths would lead to volume drop.  Any suggestions??  Thank you.
Why not? Takes 3 seconds to try.
Audio swings both ways. At best you have distorted feedback.
Not for all cases.
It isn't what "kind" of box comes in front. It is whether its output impedance is low enough to absorb the sneak-path through the blend pot. The for-sure cure is an active buffer or an active mixer.
