How to add time to rebote delay
Started by MmmPedals, November 03, 2010, 12:04:25 AM
MmmPedals
How would I increase the delay time on a rebote delay? http://tonepad.com/getFile.asp?id=98
I  know It will get messy making it too long but i want a small increase to ~650Ms
.Mike
It's simple. Just increase the size of the delay pot.
Or, you could add a resistor in series with the delay pot, but that will increase the minimum delay time. A better option would be to switch a series resistor (47K, for example) in and out of the circuit so that you have short or long settings for the delay pot. That way, when the switch was on short, you would get 0 - 50K, and when long you would get 47K - 97K.
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
Using the standard 47k or 50k pot should already give you about 700ms.
