Pedal which switches two inputs to one output...
Started by Gil, November 06, 2010, 08:52:57 PM
Gil
ok I need to build (or buy) a pedal which will be able to rout my moog and bass guitar to a bass amp,
without loosing the signal on any of the paths...
I don't mind having a separate,  dedicated out from the pedal to a guitar tuner...
Any suggestions ? Thanks !
  Mixing tends to increase signal content, first rule is the more 'stuff' your other equipment is asked to accomodate, the less 'time' it has to focus on any particular part of it.
  AMZ simple mixer, 18v supply. Simple, mixes ! I use it for mixing drum inputs, I considered just sourcing a factory one, but I had the parts and built one instead.
