3 effects in one box
Started by Brainbender, November 19, 2010, 10:08:19 AM
Brainbender
Hello, everyone!
Is it possible to make a 3 effects in one box using this layout, but to wire third effect as second on this layout?
http://www.generalguitargadgets.com/pdf/two_in_one_wiring.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
Could three effects share only one 9V power supply? Would you recommend to use 2 or 3 power jacks?
Thanks in advance!
jacobyjd
The number of power jacks won't matter. Just use 1.
You should be ok with 3 effects on one jack, provided that the total amount of current used by all 3 circuits doesn't exceed the power supply's max mAh handling.
Brainbender
