Never noticed before.... crybaby buffer
Started by ayayay!, November 20, 2010, 11:55:11 AM
DiscoVlad
Quote from: PRR on November 21, 2010, 10:33:52 PM
Stick some significant resistance in front, measure the voltage loss. You see I used 30K, an approximation of guitar impedance.
Darlington - 1,795K (**)
Single - 714K (*)
Darlington IS higher. But nothing wrong with 700K.
I fully agree, I'm just going with an "ideal" case... also being lazy :P
I didn't notice that this is NOT the stock Dunlop but an addition. I was puzzled, because it does not seem production-quality. It surely works; IMHO it could be done differently.
I suspect that the modder used resistor values intended for a single transistor, thought "input impedance of the Darlington is higher!", and used the -13 without a full re-think.
Given the way the newer boards with PCB mount jacks have been laid out, which appears to be "slap the components down randomly on the board , click the auto-router button", this is not surprising.
It's very interesting that adding 1 resistor, and tweaking the values of the other parts makes such a difference.
ayayay!
QuoteI didn't notice that this is NOT the stock Dunlop but an addition.
Not sure I follow PRR.  Are you saying the schem isn't the stock wah?  I think you're referring to one of the sims???...
I traced the circuit out last night.  :)  Alas, I did find that (at least for the current boards) that schem has one error:  The 1.8M is 2.2M.  There is a 1.8M, but it's a input dropdown resistor.  The schem is most definitely missing that one.  Other than that it's all correct.
FWIW.  Thanks!
The people who work for a living are now outnumbered by those who vote for a living.
