wiring question..
Started by FUZZZZzzzz, January 18, 2011, 08:50:26 AM
FUZZZZzzzz
i wired a dpdpt switch to a circuit like so:
http://www.generalguitargadgets.com/diagrams/switch_lo_dpdt_std.gif?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
but, the volume works on the effect when its switched on and also in bypass...
i wired a 100 k pot to the out of the pedal (lug2) and connected it to the jack out (lug3) and also lug 1 to grnd.
never had this problem before but im probably missing something..
the input from the dpdt to the pedal is not connected, because its a noisebox that should only give in to output signal in bypass mode.
if the pedal is on.. it should block the input only give sound from the selfoscillating noisebox..
thanks guys!
Jhouse
The volume pot should be wired as lug 3 is attached to the out of the effect, lug 2 goes to the bypass switch as the out, and lug 1 goes to ground.
