Signal Generator Idea
Started by trendyironicname, January 14, 2011, 01:37:20 AM
trendyironicname
My jig thread got me to thinking about something else on the back burner.  I wrote a few lines of code that would play back various wav files and stuff depending on what key you press on the keyboard.  I use an old laptop to run an oscope program.  I think it would be neat to make a box that you could run in between the headphone out of a computer and the input of your effect that would make your signal a little more in line with what a guitar by itself would give it.
We could then load the program with a strum loop, a lead loop, a "chug" loop and all kinds of other guitar wavs that we might want to test with a pedal and have a little closer to the "go pick up a guitar and try not to burn it with the soldering iron" authenticity without the guitar.  I can try to include any features that you guys would think that would make this more useful as well.
I'm incoherent from bronchitis so I can't adequately figure out what the "conditioner" should be but if yall help me come up with that, I think we could have a neat addition to our test bench.
I'm pretty sure there's a ton of functionality we could put in this and might be a fun diversion from strictly guitar circuits(although i guess this is every bit a one).
If this is stupid, blame the drugs.
There are 10 types of people in the world, those who understand binary, and those who don't.
jefe
Check out this pickup simulator that studiostud built:
http://www.diystompboxes.com/smfforum/index.php?topic=36392.msg749058#msg749058
edit: I think it's based on this: http://www.muzique.com/lab/pickups.htm
A few weeks ago, I had no idea what I could possibly use a pickup simulator for, or what it does, etc... now I think I need one. Isn't it funny how that works? lol..
ashcat_lt
Is there any good reason you couldn't just use a pickup for this?  I guess it's bigger than a transformer of similar inductance, but...
In fact, aside from noise, there's no reason you couldn't run your sample through a fully assembled guitar.  Jack sleeve in, jack tip out.
It's worth pointing out, though, that a sample recorded from a guitar will already have the signature of those pickups connected to whatever you recorded through.  Whatever happens when the pickup sim hits your test circuit will be overlaid atop that.
