waterslide decal questions
Started by mordechai, July 31, 2011, 10:26:53 AM
mordechai
A few quick questions:
1. Can I use the Dyna-Arts tone transfer stock for this process and print it on standard laser printers at a place like Kinkos?  And can the Small Bear stock work in a laser jet as well (I've heard the Xerox printers don't do well with that stock)?
2.  After printing, can I use the same sort of clear coat spray (before submerging in water) that I use to clear coat my pedal enclosures, or do I need something else?
Thanks.
John Lyons
You don't need to clear coat the decals before application when laser printing.
Any decal stock that is for laser printing can be copied.
You should use the bypass tray or card stock setting though.
Small bear sells both laser and ink jet decal stock.
Basic Audio Pedals
www.basicaudio.net/
mordechai
