Multi face fuzz adding a tone control?
Started by stompvulture, February 09, 2011, 11:21:55 PM
stompvulture
I've been tweaking the living daylights out of my ROG multi face fuzz perf board. Its insane the variations one can get, and I can't stop. Need to snag a couple rotary pots to clean up the mess. Does anyone know where to put in a tone control into the circuit?
nick d
                      Great little circuit - endless fuzzy fun !
                       Put your tone circuit between Cout and the volume pot .
                       I used a simple BMP circuit , values from Duncans Calculator
                        - works a treat !
                       My fave set-up is an old BC109 for Q1 and an AC127 for Q2 , fuzz
                       hard-wired at max - real old-school FUZZZZZZZZ
WGTP
You may need to try a 12 step program to get over it.  Great fun.
I like a 2N7000/BS170 (Mosfet) for Q1 and a J201 (Jfet) for Q2.  +1 for the Duncan Tonestack BMP.  Check the values used in the BSIABII.  ;)
Stomping Out Sparks & Flames
stompvulture
Thanks. I figured it was off the C out somewhere. I will stick a pot in there and give it a whirl. +1 on those values of the BSIABII, looks very very promising. Cheers :icon_biggrin:
nick d
                   I think I used the BSIAB2 as a start and took it from there - up a bit , down a bit , when it sounds good to you -FIRE !
