What did I just break?
Started by mrsuspend, February 21, 2011, 05:17:12 PM
mrsuspend
Oh man... nothing worse that messing up and IT'S YOUR OWN FAULT!!!  :icon_evil:
I just finished building the Orange Squeezer kit from GGG which turned out quite nicely (see pics), I'd just turned it on and verified it was working well on batteries, although on a regulated power supply there was an annoying keening tone.
I decided to try another PSU,  plugged it in, heard a horrible hum and immediately unplugged it. I looked at the power supply and realised I'd given the poor board a dose ov 9 volts AC...
Needless to say the pedal is now quite dead.
Does anyone have any suggestions for me as to how to find out what component(s) have broken? I'm grateful for any pointers!
JD only allows serving of images from his own site so here is the link to his schematic:
http://www.generalguitargadgets.com/pdf/ggg_osq_sc.pdf
/Magnus
Jazznoise
Generaly transistors are the first to go. Check those. Maybe the Op Amp. Last resort would be the diodes.
Expressway To Yr Null
Govmnt_Lacky
Seeing as you only socketed the op amp, I would try that first. It is a likely culprit and it will be easy. Replace it even if you notice no change.
After that, I recomend audio probing the transistors. Might only be one bad and it would save you some desoldering and resoldering.
Good Luck  ;D
mrsuspend
Flashback to me at the workbench a few days ago:
"....maybe I should socket those transistors?... naaah, what could possibly happen...."
Thanks both, sound advice! Unfortunately I'll have to send for parts but I can always look at it in the meantime!  ::)
/Magnus
mrsuspend
Quote from: Govmnt_Lacky on February 21, 2011, 05:38:52 PM
Where can I learn more about "audio probing"...?
/Magnus
Govmnt_Lacky
Quote from: mrsuspend on February 21, 2011, 05:57:48 PM
Search function.... Google.... etc.  :icon_rolleyes:
mrsuspend
Quote from: Govmnt_Lacky on February 21, 2011, 06:00:31 PM
I deserved those rolling eyes, it was the first hit!  :icon_redface: Thanks!  :icon_smile:
newfish
...at least the hardest component to remove *is* in a socket.
Transistors aren't too difficult to remove if you use a de-solder pump, followed by de-solder braid.
Either way, it's a neat, compact build.
Nicely done.
:icon_smile:
Happiness is a warm etchant bath.
mrsuspend
Update:
I contacted JD who offered to send me a new IC and transistors for free, including postage from the US to Sweden. Class act.
I'm sure you all know of him but if you don't: http://www.generalguitargadgets.com/
/Magnus
stringsthings
Quote from: mrsuspend on February 21, 2011, 05:17:12 PM
... I decided to try another PSU,  plugged it in, heard a horrible hum and immediately unplugged it. I looked at the power supply and realised I'd given the poor board a dose ov 9 volts AC...
Does anyone have any suggestions for me as to how to find out what component(s) have broken? I'm grateful for any pointers! ...
1) At this point, be honest about your troubleshooting abilities.  In either case, approach the problem of fried parts logically and calmly.
2) Label your PSU's clearly to avoid this problem in the future.
