Low gain Si Tranny? I think so...
Started by Brossman, March 21, 2011, 03:22:07 AM
Brossman
Hey guys,
I was rummaging through a box of electronic components in the basement where I work (appeared to have been untouched for ~20-30yrs, based on the dust), and I managed to find some very interesting stuff...
I found a box of trannies, so I started looking up datasheets.  I forgot to write them down and/or save the dataheets, but I can always go back and check.  I was surprised that one of these had an Hfe rating of min. 40 - max. 120...  I didnt even think Si-trannies were available this low. Is it possible to use these little pipsqueaks in something that is low gain (normally Ge-tranny) circuit?  Maybe say...FuzzFace?
Thoughts?
Gear: Epi Les Paul (archtop) w/ 490R in the neck, and SD '59N in the bridge; Silvertone 1484 w/ a WGS G15C
Still a tubey noobie. Been doing this a while, and still can't figure much out, smh.
newfish
Absolutely!
If you have a DMM with Hfe readings, sort your batch out into low / high order, then 'audition' the devices on a breadboard / socketed board.
If you haven't got access to a DMM, you could do a lot worse than simply swapping devices in and out of your circuit (sockets are a god-send here...)
I currently have a Fuzz Face clone with NPN Si devices of 40 (Q1), and 87 (Q2) - and it sounds great - really warm and 'bloomy'.
Good luck!
Happiness is a warm etchant bath.
Johan
look at MPSA 42/92 for real low Hfe.
J
DON'T PANIC
~arph
trjones1
Datasheet for the PN2369A show it to be in the 40-120 range, though I've never measured one below 110.  Tried some in a fuzz face, they sounded ok, but then I'm not a huge fan of the fuzz face at this point.
LucifersTrip
loads of the vintage 60's transistors I own have hfe < 20 !
The 2N2222A metal cans that are sold now have hfe ~ 60
http://www.taydaelectronics.com/servlet/the-43/2N2222%2C-Transistor%2C-transistors%2C-npn%2C/Detail
Though, a couple of my modern favorites that don't have high gains are the 2n5550's and the 2SC1815's with gains of around ~ 100-150
They've worked well in some vintage silicon fuzzes.
always think outside the box
Gus
You can also use med power transistors like a TIP29, TIP30 etc.
Brossman
Hmm, so on the topic of the FF, would I have to use a - gnd version to use NPNs, or can I rewire the circuit to run as per the old +gnd?  or...does that absolutely require PNPs?
newfish
If you have NPN devices, you'd be better using negative (conventional) ground.
You'll need to swap the +9v / Ground wires from the battery / DC jack, and also reverse the polarity of the 22uF cap (on the 'gain' pot) so the '-' terminal goes to ground.
That should be it!
mac
Quote from: Johan on March 21, 2011, 11:16:34 AM
Nice transistors, also can be found as KSP 42/92
mac
Gus
Look at transistor data sheets and note Hfe vs Ic (collector current) graphs
Hfe can vary a bit with current AND the transistor tester used.
IMO the best way to use one is to build a tester that operates the transistor at the Ic etc of the circuit you want to use it in
Search for transistor tester.
mac
Quote from: Gus on March 23, 2011, 07:33:30 AM
You can also use RG test to get hfe at different ic's. Assume leakage is zero.
http://www.diystompboxes.com/smfforum/index.php?topic=45481.0
mac
