Dr Boogey is a clone of Mesa Boogie Rectifier ?
Started by Perkla, March 10, 2011, 10:30:04 AM
Perkla
And....can i use the same components as the gaussmarkow layout.. ?  exept from the 2x10nF capacitors.. ??
And the same pots.. ?
Only the pcb layout that is different.. ?
arma61
as in that thread the link to the schematic is to the one of gauss markov I think components are the same.
about buzz or whatelse better you post in that thread, Riccardo, who created that layout, will also confirm if it's verified, though I suppose having "officially" posted schem and layout, it should be.
Ciao
A
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
Paul Marossy
Quote from: arma61 on March 10, 2011, 01:54:51 PM
Quote from: Perkla on March 10, 2011, 01:36:53 PM
. i will build it in a BB enclosure i think.. the B model is to smal...
1590B if fine, look at this
http://www.diystompboxes.com/smfforum/index.php?topic=86731.msg727151#msg727151
Cheers
Armando
I think that one is built using a "125" type enclosure...
Scruffie
Quote from: Paul Marossy on March 10, 2011, 03:29:36 PM
Cheers
Armando
It might be a 1590B, i'm not sure... If not he'll just have to go with a 1590A Then  :icon_mrgreen:
http://www.diystompboxes.com/smfforum/index.php?topic=64752.msg762076#msg762076
Perkla
I cant find a 25K-A (log) pot for the treble... can i use something else... ?
Govmnt_Lacky
Quote from: Perkla on March 10, 2011, 04:07:38 PM
You can use a 25K-B or Linear taper pot. I used it on mine. The adjustemt is not as SMOOTH as it would be with a Log taper pot (A) but it works!
Good Luck  ;D
Perkla
Ok.. i will use a 25K-B pot for the treble...
I could only find 24mm pots... so i cant use a B enclosure... i need a BB .. or else the pots will not fit in 3 in a row.. :S
Would be better with 16mm pots.. and a B enclosure.. :S but i guess a BB will work just as fine.. :D
