Distortion in EA tremolo
Started by Thugpoet, March 05, 2011, 02:19:34 AM
Thugpoet
I made a GGG EA Tremolo but it sounded a little bit dirt.It sounded like i put a ts808 in front of it,actually i did not.Though it also sounded good but how can I fix it or made it clean.
The transistor were  Q1=2n3904 Q2,Q4=2N5457  Q3=2N5088
Processaurus
The distortion is a quirk of the simplicity of that circuit.  Moving the volume control to the beginning of the circuit works, as does padding down the input.  Which schematic are you following?
Another option replace R17 with two resistors in series, then connect C9 to the centre of those.
For example,
- You can use 3.3k to the source of Q4 then to a 6.8k (and C9) then the 6.8k to ground.
  That might be enough to knock the edge off the dirt.
- for more attenuation use say 2x 4.7k's
Processaurus
Oh, duh, you're using the GGG schematic.
Quote from: Rob Strand on March 12, 2011, 02:36:46 AM
For example,
That's what I did, I think I used two 4.7K resistors there as a voltage divider, and haven't had headroom problems with my (admittedly) single coil guitars.
aflynt
I just stuck a 1Meg resistor in series with the effects input on mine. It's a bit noisy, but I can blast the input with a RangeMaster now without distortion.
-Aaron
Processaurus
Quote from: aflynt on March 14, 2011, 07:27:57 AM
-Aaron
Yeah, that accomplishes the same attenuation, but at the cost of noise and making the input shaky and super high impedance.  Making the voltage divider on the source like Rob explained isn't a difficult kludge.
