Bazzfuss with tone stack and recovery stage please check.
Started by wormfooduk, March 30, 2011, 01:04:31 PM
wormfooduk
Please can you check over this and see what you think, im away from my gear at the moment so i can't test myself.
Oh the resister at the top of the tone stack is a 22k, the Transisters are mpsa13 for the bazz and im not sure for the makeup stage maybe 5089. the pots are 100k lin for tone and 100k log for volume.
Ben N
Like this?
Might as well go whole hog and build a Whisker Biscuit. I would recommend putting back the 100k "Sustain" control after Q1 to give you the whole range from the BazzFuss decay characteristic to full-on sustain.
wormfooduk
Well i knew i wasn't braking any new ground  ;D
thanks i just wanted to know if i was on track
wormfooduk
Anyway im normally wrong, but doesnt puting the extra stage in front of the bazz fuss clipping stage buffer the signal so you don't get the interaction with the guitars volume control? I guess what ive drawn is almost the whisker biscuit with the first stage removed  :-\
Ben N
I'm not sure--I think with the sustain turned down it ought to still work. Would be worth breadboarding, and you could test it using an existing boost if you have one.
