Son of Screamer Mod Locations ?
Started by HOTTUBES, April 29, 2011, 01:52:00 AM
HOTTUBES
I have completed a few different pedal builds so far , and the one that stands out for me is the SOS OD , but i would like to
tweak it in a few spots like  Mids , Bass , treble  etc . Does anyone have any links or pics of there own they would like to share
as to where on the SOS Vero board to go about these changes .
Thanks for any help !! :icon_smile:
  Technology of the Tubescreamer, GEO...
   Capacitors have rising impedance as frequency gets lower.
    HP Filter: AC signal routed through a capacitor to an input.
  LP Filter: AC signal routed through a capacitor to a DC rail [like ground, or 4.5vdc] effectively cancelled by way of shunt.
    There are other ways in which "the 1 way all capacitors work" [looking at them as 'increasing impedance to LF's across them] can be applied:
  ..cancelling HF's of opposite phase signals [cap across where +/- are symmetrical].
  ..feeding frequency specific AC bypass to an active stage [emitter AC bypass cap or feeding opamp [opamps have + and - inputs, study opamp data sheet reads, there are many ways to wire an opamp.
HOTTUBES
Thanks Pete !! Not really what i was looking for , but good to look into in the future ..
HOTTUBES
I'm looking for more Mids & Treble from this build ...... :)
HOTTUBES
Renegadrian
As the original TS that gave its birth, the SoS takes good advantage in getting "keeley"zied.
Perform the same TS keeley mod.
HOTTUBES
What cap or resistor increases the mids ?
Thanks for your help !!
