Tube Driver Work-A-Like?
Started by azrael, May 24, 2011, 08:19:54 PM
azrael
Is there an overdrive pedal that sounds like the Chandler Tube Driver? The Tube Driver sounds cool, but it's such a pain in the butt to run.
Joe Hart
Quote from: azrael on May 24, 2011, 08:19:54 PM
Huh? It has a volume control, a drive control and a two-band EQ. It's pretty simple to run. Or am I missunderstanding what you mean by "run"? I take it to mean "operate."
-Joe Hart
electrosonic
I have a TC electronic line driver/booster (which is really just a fancy tubescreamer)  and a chandler tube driver biased to use a 12au7. To my ears they sound pretty similar, the tube driver is a bit brighter in the midrange but I think they overlap in their tonal range. If I had to choose between one and the other it would be a toss up. Maybe I lack golden ears.
Andrew.
azrael
Quote from: Joe Hart on May 24, 2011, 08:51:32 PM
-Joe Hart
I wouldn't want to use the external power supply, dude. I just want to use a normal one.
Plus, it's rather large.
So I was hoping to find a way to approximate the same tone.
Joe Hart
Gotcha! It is a little larger than a "standard" stompbox and it doesn't run on a 9V battery, so I see what you mean. I don't know anything that sounds quite like it. I don't know if you'll get real "tube sound" out of 9V. Sorry I couldn't be more help.
-Joe Hart
mistahead
If you like the "marshall in a box" idea I tend to lean towards the BSIAB circuits...
JFET boxes can emulate tubes in a couple of regards...
I don't know what the chandler tube driver sounds like (and am way too lazy to resarch it) but if the "pain to run" is an external tube and strange powersupply just rehouse it so the tube is protected and deal with the pain of one more adapter IMNSHO  :D
