Building an Orange Treble and Bass Booster
Started by zao, August 18, 2011, 04:07:33 AM
zao
Hi,
While searching for treble booster schematics, I've found this :
But my knowledge in electronic is poor, as my english!
I'm not used to this kind of schematics ; I don't understand where is the "mass" (?) - negative point - of this circuit.
Could someone help me to redraw it in a much "complete style" with a true bypass switch (stompswitch?), a 9v dc jack etc. ?
Baptiste
  http://www.generalguitargadgets.com/pdf/ggg_geb_pos_sc.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
    ...Notice how the pre-voice circuit [pot + HP filter cap] was added to
make the schematic shown in first post.
  By comparing the two schematics, how the adding of TB switching was done should be clearer.
zao
#2
What does it mean "positive ground" ? I have to connect what is symbolized by triangles to the positive pole of the 9v battery ?
  Did you look at the GGG circuit diagram ?
   http://alltransistors.com/transistor.php?transistor=44601
  The diode points from E to B in a PNP transistor, the circuit must follow the transistor polarity. Use DMM to test continuity between the points marked as 'ground' [ie we're building a +gnd circuit] and what will connect to the battery + pole.
Magnus
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
