Small bear fuzz resistor values
Started by Ymir, June 18, 2011, 04:45:23 PM
Ymir
Hi
I built a 60's fuzz face from a GGG kit. I ordered some ge transistors from small bear and installed the resistors that he recommends.
I lost the original sheet he provided that tell which ones get replaced.
Does anyone know the values of the resistors and the appropriate voltages on the transistor legs?
thx
EATyourGuitar
the 60s fuzz face schematic at GGG
I used small bear transistors in this fuzz face and it looks like there were 4 resistors that came with the transistor pair. the pigeon fx kit had 4 resistors but they are not in the photo. try to work off the fuzz face schematic that has all the resistors labeled R1 R2 R3 etc... they might not be the same in the GGG schematic but you can figure it out. just look at them side by side. I'm guessing that you bought a fuzz face pair from small bear so you want to go with that exact schematic.
WWW.EATYOURGUITAR.COM <---- MY DIY STUFF
