3PDT as on/on in midi stompbox?
Started by rudeez, June 28, 2011, 01:19:50 PM
rudeez
Hi.
I've built a stompbox to control midi using a usb gampad.
The current schematic makes it acting as a on/off switch.
Basiclly it means i have to press the switch four times to have it act as a signal sender.
Pressing it causes the midi signal to stay active instead of activate and deactive as it should have done with a momentary switch.
Thing is i need to keep the on/off function for the LED since the gamepad pcb can recive midisignals.
Im attaching a pic of the scheme i made and are using right now.
I would like to know if it's possible to wire the switch act as on/on, send a signal when pressed and release it at the same time.
I've done a post in another forum about the build with plenty of pics in the first post, take a look so you get a picture of what it is.
http://www.djtechtools.com/forum/showthread.php?t=32534
Thanks in advance!
/Jimmie
alparent
What if you connect your gamepad to the center log and GND's to the top and bottom logs?
rudeez
you mean top and bottom logs in the middle section?
alparent
rudeez
#4
The "scheme" is done in this "position".
I just tried to change the wireing on the line were the gnd is linked, changing place with that link and the gamepad data cable, like this:
|gnd
|gamepad data +
|gnd
went out so that the midi signal is sending constantly.
alparent
Tell me if I understand this correctly.
You want the switch to turn the LED on and off (on one pole)
and on another pole have the switch send +5 to your gamepad with every stomp.
Right? If not I don't understand :o(
rudeez
that's correct, exactly what you just said!
