Input cap blend pot crackling
Started by MmmPedals, July 17, 2011, 10:33:19 AM
MmmPedals
I built a brian may boost (http://www.generalguitargadgets.com/pdf/ggg_geb_bmay_sc.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a) and put a pot to act as a blend of a .0047uf film and 3.3uf electrolytic cap. The control crackles as does the volume knob on my guitar.
Is something wired incorrect?
Is there a way to solve this?
Joe Hart
I believe it is normal for the knob to crackle (I think it's something like DC on the pot). And maybe DC is going through the cord to your guitar, too? Or maybe the crackle on your guitar volume was always there, but the Rangemaster makes it more apparent? I hope this helps!
-Joe Hart
joegagan
this is a bit of a problem. my brontoboost does this sometimes as well, which has a control almost identical to yours. even with a buffer in between. but the crackling isn't bad, i try to make changes during the music to mask it. is that bad? when i put a new pot in my tele it helps a lot.
John Lyons
Measure the tip of the input jack with the pedal "on".
You should not be seeing any DC voltage.
If you do then that's your problem.
Put a 1M resistor from the circuit input to ground
to bleed off any DC voltage.
Basic Audio Pedals
www.basicaudio.net/
MmmPedals
there is already a 120k resistor to ground in the above schem.
