Help with soda meiser
Started by carboncomp, August 04, 2011, 08:10:22 AM
carboncomp
Can someone tell me what's technically happeningto the circuit when the chaos switch is flicked.
I can see it seems to remove/include a 0.1uf capacitor across the C and B of Q1, but why would that have the effect it dose of all the glitch sounds?
  A cap[ between collector/base [on a gain stage...output from collector = inverted signal output], is a LP filter.
   Only freq's above X can pass through the capacitor with low enough impedance to be 'heard', because the active stage is inverting, the HF's that Are allowed through, from C to B, cancel.
peps1
#2
Awww......Was wondering about this pedal too (as you been banging on about it Comp!)....so the switch is just a Low-Pass filter (or due to the inverting is it a HP filter?)   :icon_eek:
Teach me more please petemoore  :icon_biggrin:
carboncomp
You should know this Brook ;)
Thank you petemoore !
tubelectron
I think it is a big LPF... probably to obtain a graveyard or earthquake kind of sound, killing nearly all the treble  ???
Thanks for sharing this interesting schematic
A+!
I apologize for my approximative english writing and understanding !
http://guilhemamplification.jimdofree.com/
peps1
Dose the excessive size of the cap also increase the signals phasing you get with LPF, giving you that out of time of randomness to the signal?
Quote from: carboncomp on August 04, 2011, 02:16:15 PM
**** you!
(drinks tonight?)
