Express PCB Component Files (For Hardware) Wanted
Started by Scruffie, August 05, 2011, 11:28:41 AM
Scruffie
Does anyone have any components made for board mounted hardware in Express PCB? Looking for things like Jacks, DPDTs, 3PDTs, Toggles, Power Jacks, template layouts if you have them.
Let me know! Cheers  :)
Steve Mavronis
I can make them if you have a datasheet with the exact dimensions. It's actually pretty easy once you play around with creating your own.
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
Scruffie
Quote from: Steve Mavronis on August 05, 2011, 11:49:41 AM
I've tried but doing things with stompboxes to exact measurements isn't exactly my forte... usually a wing it and bend it or file it untill it fits person with hardware.
Well if you wouldn't mind that'd be appreciated, they're all pretty much standardized.
Here's the datasheets...
DC Jack - http://www.tube-town.net/ttstore/images/product_images/original_images/3901_1.jpg
DPDT Toggle - http://www.partsconnexion.com/prod_pdf/switch_70150.pdf
1/4 Jack - http://docs-europe.electrocomponents.com/webdocs/09c2/0900766b809c25d6.pdf
DPDT Foot - http://www.tube-town.net/ttstore/images/product_images/original_images/1461_2.jpg
I can't find one for the 3PDT at the moment..
theehman
Ron Neely II
fx schematics and repairs
Steve Mavronis
I'll take a look at each and come up with something this weekend. Do you have ExpressPCB setup to work in inches (mils) or metric measurements?
Scruffie
Quote from: theehman on August 05, 2011, 12:36:23 PM
Drop me an email and I'll send you the 3PDT.
Will do at some point this weekend (e-mails not working right at the moment) Cheers!
Quote from: Steve Mavronis on August 05, 2011, 01:43:33 PM
Cheers man, very much appreciated.
The boards are sized in metric but the components are snapped at 0.025"... dunno why I did that, so mils I guess.
Steve Mavronis
Quote from: Scruffie on August 05, 2011, 02:24:43 PM
Cool, that's what I'm used to.
Steve Mavronis
Scruffie tell me something. When you male a PCB layout with ExpressPCB, are ou etching it yourself or using their board manufacturing service?
The reason I ask is if you are etching your own PCB then do you want the part pad holes small on purpose to act as a drill center punch or do you prefer them to be sized for actual part lead diameters? I can do them both ways if you want.
Steve Mavronis
I haven't fogotten about you. My raid-0 array (twin hard drives) are failing and I have to get a new hard drive(s) and hopefully restore from backup. It's a royal pain. Then I'll get back to it.
Scruffie
Quote from: Steve Mavronis on August 05, 2011, 06:37:53 PM
Sorry! I missed your reply as my internet had gone down at the time.
With these I tend to have them etched for me, so I guess sized for the actual lead diameter makes more sense to cover both ways.
Quote from: Steve Mavronis on August 09, 2011, 11:56:17 AM
Not to worry at all! Thanks for doing them.
I was actually sent a file on the other forum before my internet got back up to e-mail you, but thank you anyway  :)
