fuzz face fuzz pot???
Started by tomwood, August 25, 2011, 04:10:26 PM
tomwood
hi, i'm having a small issue with a fuzz face build. i've built the fuzz face and sounds quite good eccept the fuzz pot does nothing, fully up fully down, no different. can anybody help?
nexekho
A photo would probably help of the potentiometer.  I don't know much about the Fuzz Face but it looks like the fuzz dial needs the middle going to ground through a 20uf capacitor with one of the legs going directly to ground and the other connected to a transistor and a 100k resistor.  Is it a PCB kit?  Perfboard?  Stripboard?  Breadboard?  Might need to cut some traces or something.
I made the transistor angry.
LucifersTrip
Quote from: tomwood on August 25, 2011, 04:10:26 PM
From the small info you've given, it is most likely a mis-wiring. A lower possibility is a bad pot.
If you'd like a more detailed & educated guess, then:
schematic & voltages are most important to start...
always think outside the box
tomwood
thanks for the replies, some more info on the build... pnp with ac128's(tested and working well), pcb is issue 1 board from pigeonfx, 33k, 470ohm, 8k2 and 100k carbon comp resistors, 22uf, 2.2uf and 0.01 caps. 500k log volume pot and 1k lin fuzz pot(thought it might be the pot so changed it and no difference)
this is the layout i used.
tested the connections to the fuzz pot which seem to be ok.
tomwood
i don't seem to be able to attach pictures
nexekho
The source for this page says the url you put in was http:// and that's it.  Try (replacing the circular brackets with square ones) (url)www.url.of/my.image(/url)
joegagan
tom , your photos or gifs or whatever need to be remotely hosted. grab the image url and put [ img ] before the tag and [ /img ] after it.  (leave out the spaces) or use the 'image' tool above, put the http in between brackets.
