Mutron Phaser II power supply using TC962CPA
Started by armdnrdy, August 24, 2011, 11:07:09 AM
armdnrdy
Hi,
I'm building a Mutron Phaser II from the ground up. I have seen where a MAX1044 has been used with success to create a bipolar power supply resulting in 8-9 volts instead of 11-12 volts as in the original design. After much research about bipolar supplies, charge pumps, etc, I decided on the TC962CPA for needed voltage and current. I have a DC Brick which has 9 VDC and 18VDC outputs. Utilizing an 18VDC output, a LM7812, and a TC962CPA, I put together a supply that I hope will do the job of creating -12, 0, +12.
Can someone please be so kind as to take a look at the design and tell me what you think?
http://www.aronnelson.com/gallery/main.php/v/Schematics-etc/Mutron+Phaser+II+power.jpg.html
Thanks,
Larry
armdnrdy
No input from anyone? I just want to be sure that this is going to work before committing this design to a board.
I would appreciate any input.
Thanks,
Larry
Seljer
Depending on what your chip can handle, take the output for the inverter chip directly from +18V then regulate it down to -12V with the a LM7912 negative regulator
cjlectronics
If you are building it from ground up then use a linear bipolar power supply.  The charge pumps are nice but they come with an internal clock frequency that can sometimes get into to your signal.  A linear supply that can push 500mA should be plenty and I'm sure you can build it for less than $10, plus it's quite (as in no ripple with the right capacitor filtering), and you can use +/- 12 or 15 volts for plenty of headroom.  Real estate is probably the only negative thing about it.
CJ
armdnrdy
Hi cjlectronics,
Thanks for the reply. I designed the board to fit in a 125B enclosure, so there isn't enough room for a on board power supply, and the interior of my pedal board's A/C power is taken up by two space grabbing wall warts. That's why I am leaning towards a bipolar design incorporating a charge pump. The TC962's spec sheet states that if you ground pin 7, it will double the oscillator frequency to 24kHz, which should render any whine inaudible. I would like to hear from those who have has a noise issue and how they remedied it. (filtering caps etc.) I also would like someone to verify that the 18VDC ground/negative serves as the 0 volt / common ground between the positive and negative voltage.
Any help is appreciated,
Thanks,
Larry
Processaurus
Your 7812 wants some .1 caps to ground on both the input and output for stability, as per the data sheet.  Also in your board layout, it would be a worthwhile precaution against noise to star ground the charge pump back at the power supply.
Don't see any other issues, but breadboarding designs before making a fancy PCB can save a lot of heartache.  I've never gotten a perfect design first shot, and PCB's are a lot squirrelier to debug than a breadboard.
