Mounting tube to perf board?
Started by mth5044, September 15, 2011, 12:02:58 AM
mth5044
Anybody come up with any good ways? Perhaps there are PCB's that you mount the tube to that put the pins into a 0.1" shape? I can't really drill a hole through the perf at the moment.
station
It's not pretty, but in the past I've drilled the hole closest to the socket leg just big enough to fit it. Do that for all the legs and then bend and solder using adjacent pads if you have to.
blooze_man
IMO, It's best to use a PC mount tube socket and bend those legs to fit the perf. No harm to the tube, and you can switch it out for another if you need/want to.
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
defaced
To add to Blooze's posts, even the point to point style tube sockets can have legs attached to them and bent.
-Mike
mth5044
So you can actually take a PCB tube and bend them so far to fit onto a perf? Do you by chance know what dimension/shape that they can be bent into, for layout purposes?
nexekho
I made the transistor angry.
markeebee
I used Nixie pins, like these:
http://www.kosbo.com/index.php?option=com_content&view=article&id=71&Itemid=79
They were pennies each on Ebay.  They're a little bit more fexible than the pins on the tube, and longer than the pins on a socket so that you can get a bit of a bend on them.
Tubes with even numbers of pins are easy to deal with, odd numbers of pins need a lttle more persuasion.  Here's a nine pin valve I stuck on breadboard, so you can see how it'll fit on perf or vero:
Zipslack
For prototyping/testing, I just use cheap and ugly old-school phenolic sockets with jumper wires soldered to the lugs.
