help on N-Jfet pls.....
Started by rx5, October 06, 2003, 10:36:16 AM
rx5
Hi  Guys!!
need your help pls.... the following are the ONLY njfet available in my area... need infos on them....
2N5458
"on" Resistance:
"off" resistance:
2N3819
"on" resistance:
"off" resistance:
2SK30A
"on" resistance:
"off" resistance:
J202
"on" resistance:
"off" resistance:
need them as audio switches for effects............. :)
thanks..
Ralph
BE d Bezt, Urz D Rezt... RoCk ON!!!
Joep
Boss often uses the 2SK30A, so this will be a good one I guess.
A lot of datahseets are on www.fairchildsemi.com or try a Google search with "fet name" and pdf (so eg "2sk30a pdf")
rx5
Im only on a dial-up and it takes a lot of time to download a datasheet, ussualy 800Kb......
brett
Here's the forward transconductances of 3 of the 4 jfets you were after;
2N5458 1.5 to 5.5 mmhos
2N3819 3 to 6.5 mmhos
j202 >1 mmhos
From memory, I think that the conductance is negatively corellated with the Vgs(off), so go for low Vgs if you want high conductance.
Off resistances are, of course, huge.
Hope this helps.  Have fun.
Brett Robinson
rx5
thanks man.... :)
needed those..... :) :) :)
-Ralph
