Ibanez FL9 is causing my DIY dirt boxes to pop
Started by Bucksears, September 30, 2011, 08:32:46 AM
Bucksears
Dirt pedals work fine when I remove the FL9?
What can I check on the Ibanez? I can't tell if anything is touching ground, but the FL9 works fine. The LED is on very faintly in bypass.
Thanks,
Buck
Govmnt_Lacky
Quote from: Bucksears on September 30, 2011, 08:32:46 AM
I could be wrong but, I believe this is an indication of very low input power.
Is this a stock unit or a clone?
Are you using battery or wall power?
Bucksears
It's a vintage/80's model. Maybe I should throw in a 9V battery and see if the results are the same.
Currently, it's running on a BBE SupaCharger.
Bucksears
Bumping this one: any other ideas as to what might cause this?
