200 ohm potentiometers?
Started by FUZZZZzzzz, October 31, 2011, 03:56:25 PM
FUZZZZzzzz
im looking for potentiometers with the value of 200 ohms, but not the trimpot but an actual pot. is it easy to bring down the value of a higher pot like 1k or something?
can someone direct me to the maths? or is it impossible to get nice results..
boogietone
Assuming my envelope math is right you will need a 250 ohm resistor wired in parallel (one outer lug to wiper) with a 1K pot.
  1       1      1
200      R     1000
Your closest values are 220 ohms or 270 ohm in the E12/E24 series, or you have a 249 ohm in the E96 series (http://www.logwell.com/tech/components/resistor_values.html).
Note that doing this will alter the effective taper of the pot turning a linear pot in to a pseudo audio pot (http://www.geofex.com/article_folders/potsecrets/potscret.htm).
An oxymoron - clean transistor boost.
FUZZZZzzzz
thank you Mr Boogietone :)
that was also the link i was looking for. maybe its easier to put a 12 position rotary in there with values between 0 and 200 ohm..
i will also try your example see if it works..
thanks!
LucifersTrip
Quote from: FUZZZZzzzz on October 31, 2011, 04:41:29 PM
thanks!
when you change a pot w/ a parallel resistor, note that the bigger difference between the R and pot, the more the taper will be skewed. So, if you're going to do that, it'd be best to use a 500 ohm pot, which is easy to get.
btw, in my sale list, I had 50 ohm and 100 ohm pots...I'll see if i have any near 200 ohm
always think outside the box
.Mike
What about getting a dual pot? Tayda has a dual 500-Ohm for $0.80.
Run them in parallel and you cover 0 to 250-Ohm, which is kind of close.
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
