Powering LED with negative voltage.
Started by armdnrdy, November 06, 2011, 01:25:06 PM
armdnrdy
Hi,
I was wondering if somebody could clarify this for me. I've noticed that more often than not an LED is powered by the negative voltage in a dual rail system. (+V, 0V, -V )
My question is: what is the advantage? Is it to balance the load?
Thanks,
Larry
Each situation varies. Every designer (  :icon_lol:  ) picks the arrangement for their own reasons, and they're often different depending on the knowledge, skill, and lunch menu (Ugh! Bean burritos again!) they have. Balancing load might be a reason. It's just as likely to be for other reasons too.
On a more existential note, LEDs don't care where the voltage/current comes from. All they know is that their head/anode is higher than their feet/cathode.
