input cap blend pot?
Started by carboncomp, December 20, 2011, 11:48:24 PM
carboncomp
Want to use this blend pot on a rangemaster, and just brad-boarding it up, but dint measure a change in capacitance with my DMM, so have I built it wrong or can someone explain why it would not measure?  (using a 4.7nF and 47nf cap)
John Lyons
The pot's resistance isn't going to let you measure the caps.
Put the caps in parallel by themselves and you can measure them.
Then use the largest then smallest cap by itself to see how they sound.
When you implement the cap blend you will not get the smallest caps
value as there is still some bleed through from the large cap though the 100k pot.
I'd make the small cap .002 or .003 and you'll have a close range to .0047 by istself.
Larger pot values will help keep the
caps more distinct (.0047 will be closer to .0047)
Basic Audio Pedals
www.basicaudio.net/
carboncomp
Thanks Mr Lyons,
So im thinking may be worth using a 100k "No load" pot if i want to keep the stock 5uf with no bleed from the larger cap?
John Lyons
Yeah, you could do that. But it's easier to just use a little smaller cap that you need.
Basic Audio Pedals
www.basicaudio.net/
carboncomp
Ok, I bread-boarded it up, and I certainly get a difference in in frequencies making it though, but its only in the last quarter tern on the pot?
Do I need to adjust any of the other parts of the RM? this is how I have it now.
runmikeyrun
try a smaller value of pot... try 50k or 25k and see what happens.
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
seedlings
Or put a resistor across those two legs where you get the 'last quarter turn'.
CHAD
John Lyons
Basic Audio Pedals
www.basicaudio.net/
chi_boy
Since its on the bread board, can you try copying the Easy Face setup for the input?
"Great minds discuss ideas, average minds discuss events, small minds discuss people." — Admiral Hyman G. Rickover - 1900-1986
The Leftover PCB Page
You might want to connect the blend pot/capacitor assembly to the base of the transistor rather than the power supply.
