Tonepad Maestro Filter Sample Hold
Started by endorphin, February 26, 2012, 02:24:29 AM
endorphin
Going to build this pedal already made the circuitboard just going to order the parts. I just wanna know has anyone had any problems with it :-\? Are there any corrections to be made in the layout?
-Andrew
60% of the time it works everytime...
chicago_mike
Just get a few NPN's for the noise transistor. Keep the wires to the pots short. Double check pinout of fets.
You should be good to go after that. You'll get ticking when its done...then you go and turn the trimpots and swap out the noise tranny.. :)
