signal switching help (CMOS or transistor?)
Started by alparent, March 24, 2012, 03:43:42 PM
alparent
I'm working on a switch box.
My setup is this an Arduino that feeds a 5v signal to transistors that switches 9v to the cd4066 gates.
But I'm also finishing a Equinox Reverb and noticed the signal switching transistor.
I'm wondering If the cd4066 is really needed in my switch box? Could I just use transistors to switch the signals?
Would that prevent any cross talk?
Or is 5v not good enough to switch a transistor passing audio signal (some issue as the cd4066)?
Don't know if this makes any sense?
Use the 4066, Alain.  The "switching" in the Equinox is simply shorting of a signal.  Your switching box has to do more than that.
