Big Muff DC Jack Replacement
Started by Ofek Deitch, March 26, 2012, 01:36:50 PM
Ofek Deitch
Hi everybody :)
Today I decided that I want to change the Big Muff's DC jack to a standard Boss DC jack.
My question is if doing this only requires me to desolder the wires the are soldered to the jack, then make the hole a bit larger using my drill, and then just re-wire the wires to the new jack?
This is the jack that's installed right now:
And these are the the Boss ones I've ordered:
http://www.ebay.com/itm/180456818724?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_1050wt_952
CurtisWCole
Sounds about right to me. Where are the two red wires going?
Curtis
Composers shouldn't think too much - it interferes with their plagiarism.
Howard Dietz
StereoKills
The two red wires should be the +9v lines (to board and battery).
Should be a simple swap.
"Sometimes it takes a thousand notes to make one sound"
Ofek Deitch
Ok thanks ! I was just making sure I'm not ruining my pedal... :)
Not unless there is some special reason to get white ones, or unless they are white because they are ceramic or something, but those look exactly like the ones I get from Tayda for 19 cents.
