Dr. boogie footswitch and LED
Started by imzuker, May 14, 2012, 04:55:46 AM
imzuker
Hello
Im building a dr boogie by Gaussmarkov.net circuit  and its my first pedal.
and i cant find the footswitch and LED i dont know if it is in the schematic,
so if it isnt there can you tellme how to add them?
thanks alot,
this is the schematic http://gaussmarkov.net/layouts/drboo/drboo-project.pdf
sure here ya go, its on his site under 'thoughts'.. ;)
http://gaussmarkov.net/wordpress/thoughts/wiring-up-a-1590b/
this is standard off board wiring for most pedals!..bookmark it!. ;)
imzuker
Thanks for the help but i didn't really understand the difference between 3PDT and 2PDT and what they actually do
and my second question is where do i connect the whole thing to my dr. boogie schematic?
you've made the pcb right?...
3pdt switches 3 ways , this way you can have an led on off too...
2pdt switches 2 ways...no led.
tip: for this pedal you will want to have a shielded input from switch to pcb or you will get radio interference ok.
i use rca lead cable,  you'll want to connect the core to the switch and to pcb in, and the outer sleeve connected to pcb ground....other end of sleeve cover with heatshrink. (no connection)
as i said above...
to stop radio interference/noise.....
cut up an rca cable...it has 2 wires in it...the inner (core)  and the outer(sleeve)
imzuker
