Question about insulators and wire connections. How do you do it?
Started by cthulhudarren, May 16, 2012, 08:56:25 AM
cthulhudarren
I am building a test circuit that uses an L200 (Pentawatt) voltage regulator for controlling voltage. I am not using a a PCB, and so I am soldering wires to the 5 pins on the L200. Needless to say, the pins are already close together and soldering wires to them is even messier. I have concerns about these touching and shorting out. I am using heat-shrink tubing but it still appears messy and doesn't cover the entire length of the L200 pins.
Is there a better way to do this without making a PCB?  Is there a type of connector that I can use that I would solder a wire to and then just connect to the L200 pins? Are there better insulating tricks and tools to do a better job covering up connections and making it also look better?
Thanks in advance,
iccaros
you can try these, Radio Shack Sells them.  your likely to kill any IC you directly solder to, as people tend to leave the iron too long in contact.
cthulhudarren
Quote from: iccaros on May 16, 2012, 09:51:53 AM
Since you need to heat-sink L200s (they're voltage regulators) I figured they would not mind getting hot enough to solder to. I just remove the tip within a second once the solder has melted. Making it look neat and clean is another matter.
artifus
use a croc clip as a heat sink whilst soldering? i often clip the legs of transistors topside when soldering without sockets for peace of mind, tho i strive to be quick and clean too.
*also* keep the sheaths from stripped wires for use on such occasions. you can build up quite a collection of various sizes and lengths which can be later put to good use.
