TS-type problem. Ticking sound?
Started by tyzjames, May 06, 2013, 01:30:58 PM
tyzjames
Hi,
I just built a TS-type pedal and I've got this weird problem. When volume is down, there is a fast ticking noise, like 300bpm. Its a little more faint when the volume is turned up. This noise goes away when I engage another pedal AFTER this pedal. I've been trying to troubleshoot but no luck yet. Connecting a 1uF elec cap and above from output to ground removes the noise. Anyone encountered something like this so far?
Thanks,
James
R O Tiree
Which schematic are you using, please?
...you fritter and waste the hours in an off-hand way...
tyzjames
Hi Tiree,
I'm using this:
Without the flipflop switching. Input and output buffers are MPSA18
R O Tiree
OK, that's a bog-standard TS schem... next question, which layout are you using, please?
